2005 Durango Power outlet problem
I have a 2005 Durango in which the front power outlet(the one under the auto air) isn't working. The other 2 outlets work fine - but as far as I can tell - those are on a different fuse than the main one. We've checked ALL the fuses and they all are working fine. I cannot figure out the problem for the life of me. Also - the little light under the power outlet(that shines onto the little area you store your change in) also doesn't work....I found a little 1 inch glass fuse sitting in that compartment that I haven't the sligtest clue how it got there - not sure if that has anything to do with the problem. We've pulled the face of the A/C/Radio unit off and don't see any loose wires or anything. Anyone have any suggestions?
ETA: Ok - the little light is working - it's just so dim I had no idea. So whatever the power outlet problem is - is it's own issue - it's not connected to anything.
Guess no one here has any ideas? Guess I gotta make a dealer appt....I was hoping to avoid that, they take FOREVER.
