2nd Gen Durango 2004 - 2009
Brake Noise
Old Sep 17, 2006 | 03:30 PM
Firefighter251's Avatar
Firefighter251
Default Brake Noise
I was having severe brake noise from the front rotors. Took back to the dealer on numerous occasions, they replaced the rotor (but not the pads) still noisy. Took back again they cut the rotors but still sounded like a freight train coming to a stop. I finally changed the brakes myself using NAPA mid-grade breaks and rotors. What a difference. If you need to replace your brakes use NAPA rotors and "TRU-STOP mid grade pads.
Just my opinion
B~[sm=goodidea.gif][sm=yikesomg.gif]
[IMG]local://upfiles/29946/D630FF81C7F84F4F9D57560CEB4014EF.gif[/IMG]
Old Sep 17, 2006 | 05:36 PM
hydrashocker's Avatar
hydrashocker
Default RE: Brake Noise
They are pretty good. I went with the ceramic pads so I have less brake dust. Anything is better than OEM brakes though.
Old Sep 17, 2006 | 10:11 PM
Mean Green's Avatar
Mean Green
Yup ceramics are the way to go when choosing brakes. They may be more expensive but the help you stop a lot better so you don't end up kissing someones rear in a heavy braking situation. My OEM pads were garbage too...
