2nd Gen Durango 2004 - 2009
need tach/crank wiring info
Old Jan 13, 2007 | 06:26 PM
jodynugent's Avatar
jodynugent
Default need tach/crank wiring info
I'm looking for info on how to get a signal from the crankshaft sensor or where to find tach wires on an 07 Durango. Application calls for a positive and negative input. Crank sensor has three wires so I don't know which is which and I can't find tach wire under the dash.
If anybody has any info it would be greatly appreciated!!
Jody
Old May 24, 2008 | 03:22 PM
rdporterjr's Avatar
rdporterjr
Default RE: need tach/crank wiring info
Have you had any luck with this? I'm looking for the same thing.
Old May 26, 2008 | 12:48 PM
Parts/Service's Avatar
Parts/Service
The wiring colors for the crank sensor are.
violet with dark green tracer is crank signal
dark blue with darg green tracer is ground
pink with yellow tracer is 5 volt supply...
Old May 26, 2008 | 04:17 PM
sca's Avatar
sca
What are you trying to do?
