2nd Gen Durango 2004 - 2009
Lift kits on 04's
Old Jun 13, 2007 | 07:36 PM
momsdurango's Avatar
momsdurango
Junior Member
Default RE: Lift kits on 04's
Yea I figured that out when we had to fix the front end a month later. We still have it on and we lowered it 2 inches cause the arms were extended to far.
I was told they will not make a lift kit for the 2nd gen durango. That stinks.
Old Oct 26, 2007 | 09:33 AM
momsdurango
Junior Member
well I did find a lift kit for it but it is 1700 and that does not include the shocks and what ever else I would need. I have not found a person here to install it. Not purchasing it till I do. I was wondering if anyone knows of a body lift for the 2nd gen durango.
Old Oct 29, 2007 | 12:19 PM
deerang's Avatar
deerang
it would be very similar to every other body lift.
youmay run into problems with your front and rear bumper lining up, your steering column may be too short, and your fan shroud on your rad may be too high.
Unless you can fabricate brackets that will allow you to drop the rad mount, and raise the bumpers, i would hold out until a kit comes around.
Old Nov 21, 2007 | 09:05 AM
AK's Avatar
AK
ORIGINAL: Hemi4wheeling
There is not anything around. Why did you not just save yourself the money and do the torsion bar lift instead? Also there is a thread on another board with a message from Truxx regarding those lift kits for the 4x4 and they said they will not sell anymore of them due to problems. They will only sell the kits for the 4x2's.
How would I go about doing the T bar lift? I wouldn't mind raising the front of my '04.
Old Oct 6, 2008 | 11:55 AM
AK's Avatar
AK
Could someone give me some info about doing a T-bar lift. I'm not quite understanding exactly what I need to do? Do I need the front completely off the ground? etc etc!
Thanks.
Old Oct 31, 2008 | 06:43 PM
chevydakidd's Avatar
chevydakidd
Originally Posted by Hemi4wheeling
That is what I needed to know. You could have ran that with just the torsion lift. That truxxx leveling kit is garbage.
Good thing i found this out because i was gonna buy the leveling kit.
Is the Readylift Leveling Kit any better?
