2nd Gen Intrepid 1998 through 2004 Intrepids
P0132 & P0152 error codes
Old Apr 3, 2007 | 10:40 PM
pdsabre's Avatar
pdsabre
Default P0132 & P0152 error codes
I have a 2002 Intrepid ES and got the error codes for the O2 sensor circuit high voltage. I replaced the upstream sensors in both banks and still get the same error codes. I am assuming the fuel mixture is running rich, any suggestions on leaning the mixture? Any help/advice would be appreciated. Thanks!
-Jeff
Old Apr 4, 2007 | 01:42 AM
Dodge Tech's Avatar
Dodge Tech
Default RE: P0132 & P0152 error codes
thoes codes have nothing to do with that the codes are for the ckts that run them either wire issue or pcm issue. Get a volt ohm meater and test the ckts from the pcm to the o2s
