2nd Gen Intrepid 1998 through 2004 Intrepids
Coolant leak saga
Old Oct 27, 2007 | 04:25 PM
dodgerman666's Avatar
dodgerman666
New Member
Default Coolant leak saga
Okay so a few weeks ago I changed my water pump and everythign was kosher...now suddenly a month later I have ANOTHER leak, this time I have isolated it to behind the engine block. this is a pretty massive leak(all of the colant leaks out in a matter of minutes), causing massive amounts of steam from under the hood. Could it be the water pump? or somethign else?
Old Oct 27, 2007 | 05:01 PM
mogyver69's Avatar
mogyver69
Default RE: Coolant leak saga
possible freeze plug
Old Nov 2, 2007 | 01:13 PM
kurts2's Avatar
kurts2
If its from the "weep hole", then it'sthe seal on the water pump shaft. If from around the pump, re-seal it. If from anywhere else, it's not from the pump (the leak), but may have been caused by the pump...if you let it overheat. If the new pump is defective and the impeller is slipping, it could cause the engine to overheat.
Old Nov 6, 2007 | 01:19 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Which engine? Makes a big differnce in the possible culprits.
