wich way did they go?
i bought my wife[boss] a2000 300m.what a great package,however a 300m came in shop on rollback yesterday.seems the inner tie rod ends severd the bolts off rack&pinion.so in other words the steering wheel just spins around and the front wheels dont respond.seems to me the owners of this car were very lucky,after all.
There is a TSB out for that... thank goodness they are okay. That's a good reason why your car should go to the dealer once in awhile, to check if your problem is under a TSB.
So glad everyone was okay!! Check yours and have the dealer do the TSB if you are worried. Is it still under factory warranty...?
~Amanda</P>
The thing with TSB's are that people usually have no idea about them. The dealers should do a better job letting the consumer know about them. It wasn't until a couple years back that I even found out about TSB's. They have saved me a good deal of money.
TSB are available on the net also at your dealer---WARNING, we(dealers)do not perform TSB's cause you ask us to. If you have a ploblem and if it is related to the TSB then we perform the repair procedure.
