2nd Gen Intrepid 1998 through 2004 Intrepids
2001 intrepid stalling
Old Dec 10, 2007 | 07:07 PM
dodge2001headtrip's Avatar
dodge2001headtrip
Default 2001 intrepid stalling
I'm a newbe so try to understand I have a 2001 intrepid 2.7 that stalls only when warmed up and at deacceleration have replaced both speed sensors,cam and crank sensors,oil pressure switch,air temp sensor all no help any sugestions???
Timming chain replace 1000 miles ago (just before it broke).
Old Dec 11, 2007 | 05:23 PM
98dakota98's Avatar
98dakota98
Default RE: 2001 intrepid stalling
could be a problem with the wiring. i know that on the 95-99 neons, the o2 sensor wire will rub on the axle and cause the ASD( auto shut down) realy to kick in and cut the car off. make sure no wires are bare or broken. bare wires can short out on any metal that they contact. also could be a problem with the ecu
Old Jan 2, 2008 | 07:54 AM
dodge2001headtrip
Thanks for the info I did look at the wiring everywhere found nothing disconected O2 sensors still same problem know anything about EGR valve?
Old Jan 2, 2008 | 04:34 PM
98dakota98's Avatar
98dakota98
to check it you can pull one of the vacuum lines off of it and either suck or blow air thru it to see if the valve opens. note: you may be able to see it on these cars. i really don't know. this is just my experience with my neon
