2nd Gen Intrepid 1998 through 2004 Intrepids
Where is the camshaft sensor located?
Old Jan 13, 2008 | 10:15 PM
bluesfool's Avatar
bluesfool
Default Where is the camshaft sensor located?
I searched and searched but I couldn't find anything, although it seems my two problems are turning out to be pretty common. I have codes showing up for the EVAP purge solenoid and the camshaft sensor...my question is where are they? Hopefully I can change them myself without having to pay the dealer.
The car is an 03 and the engine is 3.5L.
Old Jan 14, 2008 | 08:56 AM
Dodge Tech's Avatar
Dodge Tech
Default RE: Where is the camshaft sensor located?
REMOVAL Cam sensor
The crankshaft sensor is located on the passengers side of the transmission housing, above the differential housing. The bottom of the sensor sits above the drive plate. [ol][*]Disconnect electrical connector from crankshaft position sensor.[*]Remove sensor mounting screw. Remove sensor.[/ol]
REMOVAL Purge VALVE
The solenoid attaches to a bracket near the air cleaner. The solenoid will not operate unless it is installed correctly. [ol][*]Disconnect electrical connector from solenoid.[*]Disconnect vacuum tubes from solenoid.[*]Remove solenoid from bracket. [/ol]
Old Jan 15, 2008 | 10:57 AM
bluesfool's Avatar
bluesfool
Thank you!
