2nd Gen Intrepid 1998 through 2004 Intrepids
Starting Problems
Old Jan 29, 2008 | 02:12 PM
Matt228_8's Avatar
Matt228_8
Default Starting Problems
I have a 98 intrepid that i had to replace the engine on and everything went perfect with the engine swap until i went to start it, which is where my problem is. When i got the engine done and all hooked back up it would crank over and almost start but then my battery died so i had to charge the battery and when it was fully charged (which is now) it just ticks like there's a loose connection or something but there's no way there could be a loose connection if it was cranking over just fine before my battery died, anybody have any ideas what my problem could be??? any help is greatly appreciated.
Thanks Matt
Old Jan 29, 2008 | 10:47 PM
holtzer1's Avatar
holtzer1
Default RE: Starting Problems
NEVER say theres no way for aloose connection.chec the starter connection, battery connections and battery voltage. also heve someone watch the voltmeter while attempting to crank the engine...see what the battery voltage does. if it drops considerably, you have a bad battery.
Old Jan 30, 2008 | 04:22 PM
Matt228_8's Avatar
Matt228_8
I checked all the connections and they are all good and i also checked the volt meter when trying to start the car and it didnt go down that much ( maybe 8 or 9 volts).
Old Jan 30, 2008 | 10:39 PM
holtzer1's Avatar
holtzer1
have you checked the starter? try having someone tap on the starter with a hammer while you try to crank it. or remove the starter and bench check it.
Old Jan 31, 2008 | 02:21 PM
Matt228_8's Avatar
Matt228_8
The starter is brand new
Old Jan 31, 2008 | 10:33 PM
holtzer1's Avatar
holtzer1
this might sound like a useless question, but where did you buy the starter from?
