2nd Gen Intrepid 1998 through 2004 Intrepids
dodge intrepid engin light
Old Mar 18, 2008 | 08:10 PM
johnnyo1's Avatar
johnnyo1
Default dodge intrepid engin light
i was wondering any techs in here could answer this question when i leave my car in the parking lot ill get about a mile and a hlf from y job the car starts to mis fire have recently chaged out spark plugs and coils witch cost me 1,500 at sullivan tire and also had an oli change even with all that done the problem stills has not gone away my brother in law who is the manager of sullivan tire said it chould be belts whould belts cause a miss fire and then im not able to accelerate during the mis fire any ideas thanks jonathan
Old Mar 21, 2008 | 12:00 PM
kurts2's Avatar
kurts2
Default RE: dodge intrepid engin light
He is refering to the timing belt, but you may have a chain depending on the engine. If a belt, it should be changed at 120K miles (I usally only go 100K). I'd try a MAP sensor first.
Old Jun 20, 2008 | 03:57 PM
jbb's Avatar
jbb
My Mechanic is charging me to clear the code for a vacuum leak and it just comes right back on in a day or tow. He has not however found or isolated the vacuum leak. It does not appear that the performance of the car is affected but I would not know if anything else were wrong if I continued to drive with the light on. How can I determine for my self what the code is and clear it.......or better yet is there not some way to isolate the problem and repair it? The car is a 2002 Intrepid with the smaller V6
Old Jun 21, 2008 | 03:05 AM
timsalas's Avatar
timsalas
u can buy a "code reader" they will spit out the PXXXXX code for ya and you can look it up online.. the simple ones can clear Check engine lights and display the trouble code.. I think u can buy a cheapy one at harborfreight tools for about 30 bux.. or u can drive to schucks or autozone and they may even do it for free for you :-)
EDITING: NOTE: that most code readers price range is between 70 and 300 bux.. Harborfreight sells a cheay version that is good enough to read codes and reset CEL (check engine lights)
