2nd Gen Intrepid 1998 through 2004 Intrepids
Rebuilt 2.7 Oil light problem
Old Jun 3, 2008 | 07:54 AM
NVan's Avatar
NVan
Default Rebuilt 2.7 Oil light problem
Just rebuilt 2002 2.7 ran fine for about a month then oil light kept coming on when I would come to a stop then go off when I would drive, no leaks, I had put in a new Oil pump during rebuild, so I replaced the oil sending unit this worked for about a week then the light came on again and the car started to loose power, anyone have any ideas? The car still runs but only good for about 10 minutes, Oil light is still on
Old Jun 4, 2008 | 01:42 AM
tom01973's Avatar
tom01973
Default RE: Rebuilt 2.7 Oil light problem
did you turn the crank when you rebuilt the motor? sounds like the rod bearing clearence is a little loose.have you put a oil pressure gauge on it to see what the oil psi. really is?
Old Jun 4, 2008 | 12:56 PM
NVan's Avatar
NVan
Put a new Crank that came with the new barrins custom fit, on the oil pressure no that has not been checked
Old Jun 5, 2008 | 12:50 AM
tom01973's Avatar
tom01973
check the oil pressure and we'll go from there
Old Jul 25, 2008 | 10:01 AM
i3luechaos2's Avatar
i3luechaos2
Have the same problem w/ my 2002 intrepid. Seems to be common w/ the 2.7's. Hopefully it's not part of the reason my car won't start.
Old Aug 5, 2008 | 12:02 PM
pgitta's Avatar
pgitta
Junior Member
Default I had the same thing after rebuild
only mine did it from day one. Just replace the sending unit. It will go out. $10. And yes, my pressure is fine, and yours too most likely.
