2nd Gen Intrepid 1998 through 2004 Intrepids
Oil Light Blinks :(
Old Sep 19, 2008 | 06:17 PM
Fm2's Avatar
Fm2
Unhappy Oil Light Blinks :(
Well i change the oil with a mobo1 syntetic 5 - 30w change filter to a wax one and change the oil pressure sensor and the pvc valve (from dealer) and my light still blinking i also check with a oil gauge test and it has good pressure. so i guess the oil pump is good. i also insulate the oil sensor cable.
the strange think is that only show up when the AC is one and only when the car is total stop
What else do i need to do ? Thanks
Old Sep 22, 2008 | 09:25 AM
RPDalton's Avatar
RPDalton
There is a service bulletin that states that a resistor needs to be installed in series with the OP sender. Contact your Dodge dealer for the fix.
