2nd Gen Intrepid 1998 through 2004 Intrepids
Camshaft Sensor problem.
Old Oct 26, 2008 | 05:43 PM
dakster's Avatar
dakster
Default Camshaft Sensor problem.
Does anyone know where I could find the camshaft sensor on a 2000 Intrepid 2.7, and how to replace it?
Old Oct 26, 2008 | 07:19 PM
importdezign's Avatar
importdezign
The best I can do is this image. Hope it helps.It is for a 98-99 2.7 Intrepid as mine is a 99 3.2
Visit this site and for $9.99 you get a FULL online book for 7 days that you can print pages off.
http://www.eautorepair.net/
Save the image and zoom using windows image view thing. I think the forum shruuunnk the size sorry
Old Oct 26, 2008 | 10:47 PM
dakster's Avatar
dakster
one question...is this placed behind or on top of the timing cover?
Old Oct 27, 2008 | 01:32 AM
mlkmgr's Avatar
mlkmgr
i have a pic if needed, but here is the description from the manual.
REMOVAL - 2.7L
The camshaft position sensor is mounted in the
front of the head.
(1) Disconnect electrical connector from sensor.
(2) Remove camshaft position sensor screw.
(3) Without pulling on the connector, pull the sensor
out of the chain case cover.
INSTALLATION - 2.7L
front of the head.
(1) Install sensor in the chain case cover and push
sensor in until contact is made with the boss on the
head. While holding the sensor in this position,
install and tighten the retaining bolt to 12 N·m (105
in. lbs.) torque.
(2) Attach electrical connector to sensor.
Old Nov 22, 2008 | 01:06 PM
galdieri's Avatar
galdieri
Default 2004 Dodge Intrepid 2.7 Liter
can you show me a photo where Camsensor and Crankshaft sensor are located ?
Old Nov 23, 2008 | 12:57 PM
mlkmgr's Avatar
mlkmgr
pm me your email address. i cannot load photos on this site for some reason. i will send you the pic from the service manual.
Old Dec 19, 2008 | 09:57 AM
Sistinas777's Avatar
Sistinas777
If anyone has a suspected cam sensor problem with a 2.7L and it will not start at all, disconnect the plug without removing the sensor itself and crank the engine for about 10 seconds. If the car fires up, the sensor is bad. The engine management systems on these cars allow the engine to run up to 2500 RPM with the cam sensor unplugged (not removed). It will not run at all if the sensor is bad and still plugged in however.
