2nd Gen Intrepid 1998 through 2004 Intrepids
Water puddle on drivers side floorboard
Old Jan 17, 2009 | 12:02 PM
torsiondrummer's Avatar
torsiondrummer
Question Water puddle on drivers side floorboard
Hey there, I own a 99' Dodge Intrepid, 87k miles, just discovering a large puddle of water, noted several times on the drivers side floorboard, and remains damp after I dry it up. I origianlly thouth it was the heater core, but after speaking with a good friend, who mentioned he had to replace door framing gaskets? I'm hoping it is not coolant on the drivers side floor board. I ordered a new heater core, thinking I'd replace that? Could it be a leak from somewhere else? I can't see anything, and have used a flashlight etc...it's touch and go with the water accumulation. What do you think it could be?
Old Jan 22, 2009 | 03:26 AM
kurts2's Avatar
kurts2
does it only happen after a rain?
Old Jan 29, 2009 | 01:21 AM
torsiondrummer
Default I think so
You know, it was after a big snow, a couple of times. Haven't seen it sense, and sent back the heater core I ordered. I think it may be the seals, but not sure where, door, windows etc.???
Old Feb 13, 2009 | 12:45 PM
harleyjames696's Avatar
harleyjames696
have someone in the car with the doors closed and spray water all over the window and door area and see if they can see a leak. this may take a while but it does work a sprayer works good, as does a light pressure washer (dont get to close tho you dont want to damage the paint or seals)
