2nd Gen Intrepid 1998 through 2004 Intrepids
YOUR'E MIS-FIRED
Old Feb 19, 2005 | 03:04 PM
v440's Avatar
v440
Default YOUR'E MIS-FIRED
[8D] My 99 DODGE INTREPID W/2.7L HAS A DTC P0300 MULTIPLE CYLINDER MISFIRE is this something i can fix and how?Also it has 130,000 miles on it and the timing belt hasn't been replaced i don't know if that has any affect on this or not.
Old Mar 18, 2005 | 08:40 AM
moparmaniac101's Avatar
moparmaniac101
Default RE: YOUR'E MIS-FIRED
You need new spark plugs and coils badly. Afterwards, you should run perfectly. The 2.7L DOHC does NOT have a timing belt, it's driven by a steel timing chain on all four camshafts, requiring no schedule maintenance. The 3.2L and 3.5L SOHC series ARE belt driven though.
Old Mar 7, 2006 | 02:43 PM
shnormo's Avatar
shnormo
2.7 Timing chains still wear out just like any other one, and yes they do stretch out. Before you go spend about $75/coil get them tested make sure they still have the power capacity. They usually don't go bad after 150,000 miles unless you drive it like a raped ape. We had the same problem, new spark plugs didn't solve it. We had a bad crank bearing (it cracked). We got a new motor under warranty and then the code still came up. We took it back and they said it was the thermal sensor in the radiator that was malfunctioning. I think it's bull **** but they replaced it and it hasn't come back on yet. That timing chain is a pain in the *** to get to. Gotta take out the radiator, the assessories, and then the intake and valve covers and then the front cover.
Old May 12, 2006 | 09:20 PM
wannakatana's Avatar
wannakatana
ORIGINAL: v440
I had the same problem. they said the coils were shorting (to the block?). They said they replaced them. Within months it was running exactly the same, hesitating, misfiring...
Joel
