2nd Gen Intrepid 1998 through 2004 Intrepids
2004 dodge intrepid
Old Feb 12, 2009 | 04:06 PM
vettman's Avatar
vettman
Default 2004 dodge intrepid
I have been haveing minor problems with this car but this one really stumps me. I am getting a error code for a purge flow silinoid so I replaced it. the symtems for it was when you would start the car it would start normal but then the RPMs would drop and it would die. If you kept your foot on the gas a little and got going it would run rough but then it would be ok. So replacing the silinoid fixed that problem.
But now when it runs for a little while and then if I turn it off for a few minuets to go into a store when I try to start it, it doen't want to start just turns over. usually takes about 5 tries to get it started. any ideas?
Old Feb 13, 2009 | 12:28 PM
harleyjames696's Avatar
harleyjames696
are you getting any trouble code? turn the key on and off 3 times and read the p code on the dash
