2nd Gen Intrepid 1998 through 2004 Intrepids
ATC Display; Troubleshooting
Old Feb 18, 2009 | 10:22 AM
TheTruthx34's Avatar
TheTruthx34
Default ATC Display; Troubleshooting
Hey everyone, I own a 2000 Dodge Intrepid and for the past year or so, the Automatic Temperature Control Display has not been working. To get through the winter, I just set it at the highest possible temp. and if it gets too hot i turn it off. When I went out this morning, it was working perfectly! Then on my way back home, it was back to no display. Anyone have any methods of trying to fix this?? I tried going to Firestone to get a quote on it but they would need to take apart the center console in order to do so.
Thanks
Old Feb 18, 2009 | 11:14 AM
kurts2's Avatar
kurts2
Probably the control head (display itself). It could be the BCM (computer for dash, lights, entry, alarm, etc) or wire problem. To isolate, a DRB scan tool should be used (the head d/n need to come out for this and a Dodge dealer can scan in a min.).
If it is a head (BTW I've seen them on ebay much cheaper in the past), it's easy to install.
If its the BCM, the VTSS (an anti-theft system) has to be enabled with the DRB III scan tool after its replaced. The only place I know to get this done is the dealer. You may want to reconcider going to Firestone for this.
