2nd Gen Intrepid 1998 through 2004 Intrepids
2002 Intrepid transmission problem
Old Mar 5, 2009 | 07:32 PM
ridgehill's Avatar
ridgehill
Default 2002 Intrepid transmission problem
Hi All'
2002 Dodge Intrepid transmission problem
Codes are:
P0733 3rd gear incor ratio
P0734 4th gear incor ratio
P0841 low and rev clutch pressure switch
P0944 loss of Hyd pump prime
P1684 Battery pw to module loss
P1790 malfunc after shift
The car was running fine until this problem 2 weeks ago. At a stop light was the first time. It didn't start out, then dropped into gear. It happened two more times after that. I tried to get it to do the same thing a couple a days later when trouble shooting. It drove with no problems so we cleared the "check engine" light and drove the car for another week until finally the problem arose again. We checked the computer codes and they are as shown. Any help would be greatly appreciated.
Thank You
