2nd Gen Intrepid 1998 through 2004 Intrepids
97 3.5L Intrepid - Starting Problems
Old Mar 12, 2009 | 09:53 AM
rich5405's Avatar
rich5405
Angry PLease Help!
GREETINGS. LET THE FORCES BE WITH YOU.
My Ride is a 1997 3.5L Intrepid.
For the last couple weeks my car may/may not start; using battery cable jump (in park), or by switching the gears from park to drive, or from park to neutral, etc.
Now I'm getting only clicks and the engine will not turn over. I replaced the fuel pump sometime last year; I can hear the fuel pump when I turned the key.
Battery was left overnight to re-charged.
Ran the ignition key test and got the following codes: 12 and 55, (I had loosen the terminals earlier as I was removing the battery to get it tested). The service shop found no problem with it. Battery Terminals are clean and tightly secure. Dashboard and interior lights are bright and does not dim when switching the ignition on.
Later today I planned on checking both ends of the battery (+/-) terms wires to make sure the connections are secure. Will check the engine ground wire also.
Could this be a possible neutral control switch issue or something else? Where would I locate the neutral switch/relay?
I will appreciate any help. Thanks!
Old Mar 12, 2009 | 07:05 PM
Kindschi's Avatar
Kindschi
Only help I could Suggest is to post in the correct Forum. This is the 98+ Intrepid (2nd Gen) forum, you need to post yours here https://dodgeforum.com/forum/1st-gen-intrepid-91/
Old Mar 13, 2009 | 10:04 AM
rich5405's Avatar
rich5405
will do so..
