2nd Gen Intrepid 1998 through 2004 Intrepids
99 3.2l interpid HELP PLEASE!!
Old Mar 13, 2009 | 05:14 PM
five point h0e's Avatar
five point h0e
Default 99 3.2l interpid HELP PLEASE!!
hey guys..i gotta 99 3.2litr intrepid
here is my problem
every once an a while( like once a week or so ) ill go too start the car and it will start up then it will like spit sputter an than shut off..if before it shuts offf i hit the gasss a good bit it stops it from shutting off and than it idles good..also like when im sitting at a longgg red light the idle will like bounce up an down than go back too like 650?
i jus changed the plugs, so it could be a ton of other things, coil packs, tps sensor
anyone got any hints or anyone have this happen before..help would be greatly appreciated
thanks guys!
Old Mar 20, 2009 | 11:31 AM
kurts2's Avatar
kurts2
MAP sensor. This is exactly how my sticking sensor acted. unplug to verify (will use default value and run fine at idle/low RPM...enough to get you home or to the parts store). You can also use a higher end scan tool (one with real time monitoring) and see the value stuck.
Old Apr 7, 2009 | 10:12 PM
intrepid22"'s Avatar
intrepid22"
kurt is right it is the map senser i had to replace mine an sounds the same cheap fix
