2nd Gen Intrepid 1998 through 2004 Intrepids
problem removing valve body
Old Mar 25, 2009 | 03:17 PM
richard43's Avatar
richard43
Default problem removing valve body
Having trouble pulling valve body. Car is on ramps, have taken manual shift lever off- after turning clockwise to rear of car, and pulled position sensor harness, but body wiggles and is not dropping. Is it possible that front wheels need to be free- or is o ring on man shift post and sensor dried tight.
Pan and perimeter bolts are off
Old Mar 25, 2009 | 08:18 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Welcome to DF Rich! What model of car do you have? Once I figure that out Ill be able to help point you in the right direction
Old Mar 25, 2009 | 08:46 PM
Parts/Service's Avatar
Parts/Service
Welcome,post up what kind of vehicle you are working and I am sure help will soon follow.
Old Mar 26, 2009 | 07:57 AM
richard43's Avatar
richard43
Default 42LE valve body
2003 Intrepid ES had a P1776 code after warm-up. Was pulling valve body to replace solenoid pack, but seems stuck -
Old Apr 30, 2009 | 04:56 PM
richard43's Avatar
richard43
shift post o-ring was dried tight- used penetrating fluid and reached up and pulled down with a glove hand while right hand held body from falling on ground- keep your head away !
Old Apr 30, 2009 | 05:29 PM
lghtngblt02
Ok Richard, I moved this over to the 2nd Gen Intrepid Section, hopefully someone can give ya some advice on how to tackle this problem alittle better! GOOD LUCK
