2nd Gen Intrepid 1998 through 2004 Intrepids
Rough starting 3.2
Old Apr 27, 2009 | 10:09 PM
Rider500's Avatar
Rider500
Default Rough starting 3.2
I have 01 3.2 and when the engines warm it doesnt start good. It turns over 4 to 5 times before it will fire and when it does the engine hesitates before settling to the correct rpms, once running its perfect and i havent noticed any decrease in mileage. It also smokes blue for a little while. It starts fine when its cold or hot. Plugs are new and maintanence is always done on time. Any ideas?
Old Apr 27, 2009 | 10:21 PM
cnctony's Avatar
cnctony
Yea I have a few....
1. Take to local shop and check fuel pressure. Regulator could be out and pressure is too high causing flooding when starting hot. I have seen this before.
2. I would check the EGR valve they can get sticky and cause all kind of problems.
3. I would put OBDii scanner on it and check the O2 sensors, engine temp sensor and timing advance.
That should catch it.
Good luck
Old Apr 28, 2009 | 05:06 PM
Rider500's Avatar
Rider500
I already checked the fuel pressure and its to the correct specs. It also does not drop below 30 psi after 5 min(service manual specs) and the throttle body was cleaned. If thier was a problem with one of the sensors would it display on the dash when you search for trouble codes or would you need a scanner to retrieve it? Thanks for the help
Old Apr 29, 2009 | 10:17 PM
cnctony's Avatar
cnctony
Well you checked the fuel pressure but didnt check anything else I sugested.
Ok if it starts and runs fine when cold but not hot(you weren't very clear) YOU SAID when the engines warm it doesnt start good. It turns over 4 to 5 times before it will fire and when it does the engine hesitates before settling to the correct rpms, once running its perfect and i havent noticed any decrease in mileage. It also smokes blue for a little while. It starts fine when its cold or hot. Apparently according to you the only time theres a problem is when its warm, not hot or cold.
Then check IAT sensor, and ECT sensor.
Old Apr 29, 2009 | 10:51 PM
Rider500's Avatar
Rider500
Yeah it only starts rough when its warm, if its cold or hot it starts good. I didnt get to checking the egr valve yet and ill check the sensors. Thanks
