2nd Gen Intrepid 1998 through 2004 Intrepids
Radiator Cooling Fans--When do they kick on?
Old Sep 24, 2009 | 11:24 PM
shill147's Avatar
shill147
Default Radiator Cooling Fans--When do they kick on?
Just changed out the thermostat in my 98 Intrepid. Upon testing the engine, I noticed the radiator fans were not running with car roughly halfway between Hot & Cold on temp. guage? At what temp are fans supposed to engage? What would prevent them from kicking on? Solenoid? How hard is the fix?
Old Oct 1, 2009 | 04:22 PM
22dodge's Avatar
22dodge
come on with A/C request
@ 212°F 100°C coolant temperature.
What makes them not come on:
- bad fan
-wiring problem
-Relay problem
-power problem IE fuse
-ground problem
-bad thermostat stuck open preventing engine from fully warming up
-a/c inop.
-defective coolant temp sensor.
-engine had not reached request temp
a quick test to see if the PCM is able to turn on the fans is to disconnect the engine coolant sensor. this will put the PCM into limp-in which the fans will automaticly come on. if they don't you need to have some more indept diagnostic done.
Old Oct 16, 2009 | 04:48 PM
DESIREESAVENGER's Avatar
DESIREESAVENGER
Fans don't come on until 225-230.
