2nd Gen Intrepid 1998 through 2004 Intrepids
2002 Intrpid: Ignition switch problem?
Old Oct 3, 2009 | 02:01 PM
jsocki's Avatar
jsocki
Default 2002 Intrpid: Ignition switch problem?
Some bizarre problems related to the ignition switch: After starting, the air bag light comes on. If I move the key CCW a bit AND have the AC on, the air bag light goes out. If the AC light goes out, the drivers window won't work.
I think this is related to an intermittant short in the ignition switch cable harness. Has anyone else had this problem? Is there a solution?
