2nd Gen Intrepid 1998 through 2004 Intrepids
Hepa Filters on a 2000 Dodge Intrepid?
Old Oct 23, 2009 | 03:42 PM
jbird65737's Avatar
jbird65737
Question Hepa Filters on a 2000 Dodge Intrepid?
Are there any Hepa Filters on a 2000 Dodge Intrepid? If so, where are they located? I get a bad "musty" ,"dusty" oder coming from my vents when I use heat and a/c. Was wondering if there are any filters inside the dash that I could change, and if not what can I do to get rid of this smell?Thanks, Jackie
Old Oct 23, 2009 | 04:20 PM
DESIREESAVENGER's Avatar
DESIREESAVENGER
No filter. The smell is coming from the evaporator. You can try some Frigie Fresh but more than likely when you turn the ac on in the spring it will be warm because the evap is leaking.
