2nd Gen Intrepid 1998 through 2004 Intrepids
2001 Intrepid 2.7 Stalls
Old Dec 14, 2009 | 02:38 PM
helpmeplease's Avatar
helpmeplease
Default 2001 Intrepid 2.7 Stalls
Hello, new to the forum and need help
I have a 2001 Intrepid and recently when I am driving off the highway into the city the car stalls.
This is now happening on a daily basis, the car starts up again and does not have any more problems. This does not happen with regular city driving. ANy help is appreciated.
Old Dec 21, 2009 | 11:12 PM
RGB838's Avatar
RGB838
Default 2001 Intrepid Stalls
I have a similar posting for a 2000 with a 3.5 doing the same. Ours started when the temp outside is in the 30's. Have you had the codes read?
I'll let you know if we figure ours out.
Old Dec 22, 2009 | 08:18 AM
helpmeplease
I have have attempted to have the codes read but nothing came up.
So far in my searches, either the MAP sensor or Oxygen sensor. I talked to my mechanic and he is also going to start to research the problem after the holidays to see what he can find. One of the last honest mechanics, will not do unnecessary work on a vehicle. He tells me his reputation is on the line if he rips off his customers. One of the few independants around as well.
Old Jan 10, 2010 | 11:42 AM
deezozdodge's Avatar
deezozdodge
Could be a compression problem.
Old Feb 3, 2010 | 03:34 PM
choirboyjr45@hotmail.com's Avatar
no its the peice of crap PCM and transmission module acting up if you want to call a guy who works at countryside auto in johnstown ohio and if you ship it to him he'll fix it, he own a intrepid that had the same problem
Old Feb 9, 2010 | 06:23 PM
kurts2's Avatar
kurts2
If you have an obd2 reader that can monitor real time, it may help see what's going on. I'd lean towards the map from what you posted. If so, you will see the hg stuck with the scan tool.
Old Feb 24, 2010 | 01:04 PM
apappal's Avatar
apappal
I have an 2001 that did the exact same thing when exiting the highway. After everything else it was the EGR valve that was mechanically sticking and causing the car to stall. It wouldn't set a code because the electronics to the valve were working.
