2nd Gen Intrepid 1998 through 2004 Intrepids
Problem after 2.7 to 3.5 swap
Old Dec 21, 2009 | 02:29 PM
RGB838's Avatar
RGB838
Default Problem after 2.7 to 3.5 swap
Put a 3.5 in a 2000 Intrepid after the 2.7 blew. Has ran great (10K + mi.)until cold weather. Now it stalls after about 2 miles when temps are in the 30's. starts right up & runs fine after the stall. Code says open EGR circuit, cleaned egr & checked all voltage & resistance test fine. Do think may have coolant leak at intake rear drivers side. no coolant expose but can smell it & after hard drive some steam shows in area. may use a quart in 3K miles.
Suggestions
Old Dec 21, 2009 | 02:44 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the Intrepid section,
FF
Old Dec 21, 2009 | 06:31 PM
RGB838's Avatar
RGB838
Thanks I'm learning
