2nd Gen Intrepid 1998 through 2004 Intrepids
Factoy Amp Bypass on 2004 Intrepid
Old Jan 14, 2010 | 11:02 AM
JuggaNinja's Avatar
JuggaNinja
Default Factoy Amp Bypass on 2004 Intrepid
I know this question has been asked a million times. I installed an aftermarket radio in my 2004 Intrepid SE and with the stupid factory amp, there is no sound. I don't know if it has Infinity I or II installed either. So, I need to know the cheapest, doesn't matter if it's the hardest, way to locate and/or bypass my amp so I can get some damn toons bumping. Never dealt with factory amp before so new to that but have uninstalled and installed dozens of radios and speakers. Please be exact and pictures never hurt. If you think it's easier to e-mail me fine ,whatever, just ask and I will supply. Thank you to all that can help. Also I have my own amp. If I can swap these it'd be much perfered.
Old Feb 18, 2010 | 07:53 PM
rfortner89's Avatar
rfortner89
Did anyone ever give a solution to this? if so, can someone fwd it to me?
Old Feb 23, 2010 | 03:10 PM
shak541's Avatar
shak541
hello i do car audio! .. lucky you... if you want you can keep the factory amp by running RCA's if needed to the amp.. or run just a new remote on to the amp and it should work.. personally i would recommend bypassing the factory amp if you have an aftermarket HU as factory amps arnt the greatest it just involved running new speaker wiring to the doors .. if you want email me at shak541atgmaildotcom and i can help you personally and quicker there
Old Feb 25, 2010 | 01:54 AM
rfortner89's Avatar
rfortner89
Thanks alot! I actually found a friend of a friend who i have become really close with and he knew how to do it. He figured it out in about 10 mins. He did exactly what you said to do but he used the factory wires that were already in the car.
Thanks so much!
Old Feb 25, 2010 | 07:30 PM
shak541's Avatar
shak541
lolz.. np .. glad i could help. a little note.. if you install an aftermarket HU its best to run new speaker wires to bypass the factory amp
