2nd Gen Intrepid 1998 through 2004 Intrepids
2.7 idle messed up when warm?
Old Feb 24, 2010 | 04:50 PM
shak541's Avatar
shak541
Default 2.7 idle messed up when warm?
hello i have tryed alot to fix a low idle on my car with no success.. it tends to run fine when cold.. but when it warms up it roughens up... enough to almost stall!!. basically i was wondering if u guys know where the injectors are and the IACV(idle air control valve) ive read alot about this and im guessing IACV.. as the car runs fine in all cases.. just the rough idle when warm!!.. i tried to relearn the ECU with no success .. thanks a lot if you know where these parts are: injectors and IACV on the 2.7
Old Feb 25, 2010 | 12:04 PM
kurts2's Avatar
kurts2
See holy Grail post at top of second gen fourm. While in the book, be sure to read about open vs closed loop also.
Old Feb 25, 2010 | 07:35 PM
shak541's Avatar
shak541
umm any chances you know approx whereabouts that section is? thanks alot
Old Feb 26, 2010 | 07:55 AM
kurts2's Avatar
kurts2
No, but after you open the PDF, just use the search/find feature to locate those key words.
