99 Intrepid Not Starting?
My wife drove her Intrepid home with no problems at all. The following morning she said it wouldn't crank. The car spins over fine and the fuel pump is running like usual. So I pulled out a plug to see if it was sparking. No spark. I swapped the relays around in the fuse box and this didn't help. Anyone have this happen to them before?
ORIGINAL: dodgemech
That vehicle has individual coil packs, if one was dead, car would still run with a missfire. I would guess at can/crank sensor not triggering pcm
