2nd Gen Intrepid 1998 through 2004 Intrepids
Water Pump Weep Hole
Old Apr 10, 2010 | 02:03 PM
swithrow's Avatar
swithrow
Default Water Pump Weep Hole
What kind of problems can you cause by adding pressure to the cooling system? I notice almost instantly some water coming out of the weep hole just below the thermostat housing on my 2.7.
Old Apr 12, 2010 | 11:21 PM
kurts2's Avatar
kurts2
The cap regulates the pressure... What do youean add pressure?
Old Apr 13, 2010 | 01:18 PM
swithrow's Avatar
swithrow
Through the reservoir tank. I decided to replace the water pump, (What a pain). I got all the way to the chain cover (105 in lbs per bolt), and on the very last cover bolt the damn thing popped and i noticed a 2 inch crack in the cast. I have a cover on order.
