2nd Gen Intrepid 1998 through 2004 Intrepids
code Po1391
Old Apr 24, 2010 | 01:59 AM
pabe's Avatar
pabe
Default code Po1391
Replaced a 2.7L in a 2000 chrysler intrepid and it will miss and sputter when it is cold. Once it gets warmed up it is fine. A code po1391 is in the computer. Thanks for the help. By the way I have installed a new crank and cam sensor.
Old Jun 13, 2010 | 07:25 PM
MGM92's Avatar
MGM92
For my 2002 intrepid 2.7L. P1391 is for the loss of a cam or crank shaft position sensor.
I would go to a mechanic with a OBD 2 reader. he can plug his computer into your car and tell what the code means.
Old Sep 7, 2017 | 12:08 AM
owner.of.98.intrepid.es's Avatar
Default Hoping you're still a member.
I realize this posted 3 to 4 years ago, but hopefully one of you can help me. I have a 1998 Intrepid ES with a 3.2L. I went through all the same things you did. I have one more to try a fuel line pressure test if that comes out good I'll be at a loss.
If you tried the PCM and fixed the problem let me know.
Thank you, Kelley
