2nd Gen Intrepid 1998 through 2004 Intrepids
LF tire wobble ???
Old Jun 3, 2010 | 12:27 PM
J_Copeland's Avatar
J_Copeland
Default LF tire wobble ???
I get a serious LF tire wobble while turning right at speeds above 30.Just happened last night for the first time on the highway.i thought I had a flat at first.
I'm thinking inner tie rod end bushings.
Any idea's?
Thanks,
Old Jun 4, 2010 | 11:01 AM
kurts2's Avatar
kurts2
That would be my fist item to look at also. If it is bad, there is a rubber and metal insert replacment availble for $10. It's the job of getting to it that's a pain! It's under the intake plenum between the engine and the firewall.
Old Jun 5, 2010 | 09:08 AM
deezozdodge's Avatar
deezozdodge
Yes, I agree with kurt2. Lift the car and shake the tire with your hands, both up and down and side to side. There should be no play. Be sure to check the other side to. Have a friend help you locate the bad bushing or any other part that is defective.
I had a wobbling/vibration problem and found that a bushing near the rack by the firewall was defective. I replaced both and all is well. Good luck
Old Jun 5, 2010 | 09:18 AM
J_Copeland's Avatar
J_Copeland
Thanks guys.
I replaced the bushings yesterday,the drivers side was almost completely gone.
Wow,what a difference.
It feels like a new car now.
Old Jun 5, 2010 | 10:02 AM
kurts2's Avatar
kurts2
Yea, I rember after I changed mine I realized just how loose the steering had been only after I had it so tight again.
