2nd Gen Intrepid 1998 through 2004 Intrepids
3.2 Heating Issue Diagnosis
Old Aug 14, 2010 | 10:12 AM
MDThomas26's Avatar
MDThomas26
Default 3.2 Heating Issue Diagnosis
I thought I had a blown head gasket becuase whne this thing heats up it heats up QUICK! However, it doesn't always do it. It will heat up quick then the temp drops right back down. It ins't consistent either, like sometimes it will happen going down the road but not others, sometimes it will happen at a stop light but not other times.
Also, I don't have any white smoke or anti-freeze smell. Could this be an electric fan? How could one go about testing that?
Old Aug 15, 2010 | 03:10 AM
sapporo's Avatar
sapporo
how this one would go about testing is I'd use my scanner and read the actual temperature the pcm is seeing, then i'd verify the fan is functioning using my scanner to activate fan control.
Old Aug 15, 2010 | 06:41 AM
kurts2's Avatar
kurts2
May be a false indication. Test the actual engine temp.
Old Aug 15, 2010 | 08:27 AM
sapporo's Avatar
sapporo
which is why I would go about using a scanner to see what the computer is seeing for temp.
