2nd Gen Intrepid 1998 through 2004 Intrepids
2002 Dodge Intrepid Freeze Plugs
Old Sep 19, 2010 | 12:16 PM
womanofaith08's Avatar
womanofaith08
Smile 2002 Dodge Intrepid Freeze Plugs
Could anyone tell where exactly the freeze plugs are located on a 2002 Dodge Intrepid? It would be of great help. Thanks
Old Sep 19, 2010 | 03:04 PM
sapporo's Avatar
sapporo
no, because you didn't state what engine. but most all engines have freeze plugs in the engine block and in the cylinder heads.
Old Oct 1, 2010 | 12:05 PM
Matt31's Avatar
Matt31
Default Dodge Intrepid 2002 2.7 freeze plug location
(WOMANOFAITH08)
they're located on the cylinders and the engine block.
*You have to take off the cylinders to get to them, NOT EASY because you have to take everything off.
each cylinder has 2, one in the back and one on the front side.
>the engine block has 2 on each side. One is on the back side and front side of the engine block.
* the one that's on the back side is very tough to replace, the exhaust manifolds is attached to the catalytic converter and almost blocks you from getting to them. the one that's on the front side is a lot easier.
Hope this helps.
