2nd Gen Intrepid 1998 through 2004 Intrepids
2001 SE Interior Lights Out.
Old Nov 29, 2010 | 08:50 PM
toddk01's Avatar
toddk01
Default 2001 SE Interior Lights Out.
Hi,
I'm a n00b on here and did a search for BCM issues regarding the interior lights not working when door opens and supposed to fade-out when door closes but didn't find a specific. From what I've seen the BCM may be the culprit. That thing does a lot regarding the interior. The kicker symptom seems to be that the dash lights (dimmer function) seems to flicker on it's own now and again. I don't get the whole headlight flash as I've seen from other posts. You can manually operate the front dome lights so there is power there on demand. I just want some insight as to this issue before I try to replace the "Gold Plated" BCM. It is the 2.7L SE. Thanks in advance for any of your help. You are the experts. -Todd
