2nd Gen Intrepid 1998 through 2004 Intrepids
98 dodge intrepde 2.2 3cyliner misfire
Old Jan 8, 2011 | 01:02 AM
caravanman1966's Avatar
caravanman1966
Arrow 98 dodge intrepde 2.2 3cyliner misfire
I have a 1998 dodge intrepid.2.0l , I have done a diagnostic and it says it has a misfire in the #3 cylinder.
The car does run rough and miss's , but there is nothing else wrong that i have found.
mileage is 155,000
nee some answers before i get into some money old this older model card.
thanks
p:s could it be . coil, as plugs and wires have been changed?
Old Jan 8, 2011 | 06:22 PM
kurts2's Avatar
kurts2
To make sure you didn't get a bad plug or wire, swap them to another cyl. Next I would look at the injector, you could run a cleaner or have a shop that runs a cleaner under pressure ...I don't think the coil because it SHOULD throw a code.
