Does anyone know where I can get a diagram of where these are, and how to get them out, and possibly what tools will be needed? I know they are on the top of the gas tank, but I want to know more about it before I try to tackle it.
Well, IDK what you tell you. I can walk into my neighborhood dealer and get all kind of kindness, service manual information and diagrams as I need them.
you need to drain the gas tank to make it lite weight. it should have a drain plug on the bottom . u can try to lower the charcoal canister on the passenger side of the car, before lowering the tank .but taking the age of the car the mounting nut is rusted . so empty the tank land lower it to access the ldp above the cannister.there are 2 8 mm screws on the inside facing tank .
Must be nice, you can't do that here. They would charge an arm and a leg.
We give out these infos for free is you come in at late hours (Not busy).
I donno what to tell you, but I believe you need to drop the Gas tank in order to get to whose items. At least drop Half of the tank, support it with a jack, and try to reach ur hand in there.
If you try to do this on the ground, I recommend you to Completely drain the gas tank first as mentioned. I don't like the idea of the Drain Plug, they are Plastic, they break real easy, especially on an Old car.
