2nd Gen Intrepid 1998 through 2004 Intrepids
Have codes P0068 and P0108
Old Apr 20, 2011 | 06:02 PM
saxmo59's Avatar
saxmo59
Default Have codes P0068 and P0108
My intrepid also exhibits the same sign's that TopGlock describes i.e stalling once the car stops but the two codes present an array of possible problems including transmission,timing etc.I have tried to find any vacuum leaks and come up empty just like my wallet and am looking for some advice on where to start.The last place that looked at it said that it needs more repair than the car is worth with 332,000 miles and to drive it till it dies.
Any help would be greatly appreciated!
Old Apr 21, 2011 | 08:53 PM
kurts2's Avatar
kurts2
Sounds like a sticking MAP sensor. You can try unplugging the electric connector and see if it stops stalling. With it unplugged, a default value is used by the PCM (limp home mode). With it unplugged, the stalling at stops should stop occurring if the sensor is at fault but the car will not run we'll at high RPMS or under acceleration or load. This is only to aid in trouble shooting.
Old May 2, 2011 | 06:19 PM
saxmo59's Avatar
saxmo59
Default map sensor troubleshoot
Tried disconnecting the MAP sensor and the car would start but die after a few seconds.Not really sure what to do next but take it to the dodge dealer and see what he says.
