2nd Gen Intrepid 1998 through 2004 Intrepids
2002 Intrepid Running weird
Old Mar 9, 2012 | 01:32 PM
theweave's Avatar
theweave
Default 2002 Intrepid Running weird
My 2002 Interpid has been running weird.
The engine light is on & periodically the engine light will start blinking & then the car will run very rough/start shaking. It will also hesitate when excelerating when it is doing this. After a few minutes it will stop & then run fine. It has stalled on my once or twice when it does this as well.
I had it looked at & the O2 sensor was throwing off the engine light. Mechanic did a tune up, checked the O2 sensors (they were fine), replaced the vacuum hose that was dry rotted. He topped off all the fluids. Said everything looked good.
After about week the engine light is back on & is doing it still.
To me, it sounds like the engine is not getting enough oxygen or something with the fuel components.
Any ideas would be great!!!
Old Mar 12, 2012 | 12:36 AM
kurts2's Avatar
kurts2
Replace the map sensor
