2nd Gen Intrepid 1998 through 2004 Intrepids
2001 Intrepid 2.7L water leaks behind the Engine Block
Old Apr 1, 2013 | 11:00 PM
Intrepidspeeder1999's Avatar
Intrepidspeeder1999
Default 2001 Intrepid 2.7L water leaks behind the Engine Block
As I was adding Coolant and Water the the Reservor
I noticed coolant was leaking form the Back of
the Block and Flywheel, I dont understand why my
its leaking.
I checked the heater Hoses they were not Leaking.
Im thinking maybe theres trapped air in the Block
maybe that coolant is leaking from
the Weep Hole.
Anyone has any suggestions??
Old Apr 4, 2013 | 01:10 PM
Intrepidspeeder1999
its leaking.
the Weep Hole.
I guess no one knows lol
Well Im gonna take down the Transmision just too see
where that leak is coming from, once Im at it Im gonna replace the Rear Main Seal it leaks engine oil
Old May 8, 2013 | 11:35 PM
mopes1967's Avatar
mopes1967
HAVE YOU FOUND THE SOURCE OF YOUR LEAK? I have an 02 with a 2.7 lr that has just started leaking from an invisable place at back of engine.
