Can someone help me with these codes please
Whats up guys im new to this site and was wondering if someone could help with some codes
that came up on my intrepid
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
can anyone please help please any suggestions appreciated thanks ........
You either have a problem with your sensors, or the wiring going to them. Test the wires to make sure that you have the rightvoltages in the right places. The best way to test the sensors themselves is to watch them on a scan tool.
whats up Tchase just wanted to thank you alot as i belive your right i found a wire rubbing up against the drive belts so im assuming that was the proble thanks for your help now on to fix it
Thanks again
Thanks again
Your very welcome. That was acually kim (me) tonys feiancee. Iam also on here as Neon Lights when iam on the computer at work. Iam a apprentice at a small two bay shop. I hope this proves to fix your problem. Happy Motoring. ;-)
Chances are I would say that it is the sensor itself as that is a common issue with Treps. If the sensor is sending to high of a voltage and sending the signal to the computer it will cause lean issues by cutting fuel.
