2nd Gen Intrepid 1998 through 2004 Intrepids
2002 2.7 Intrepid timing issues
Old Dec 5, 2013 | 02:46 PM
cliffordferguson85's Avatar
cliffordferguson85
Default 2002 2.7 Intrepid timing issues
I purchased a 2002 Intrepid with a 2.7 L engine that had a bad water pump. Changed the water pump, timing chain, guides, tensioner, camshaft position sensor, crankshaft position sensor. Car run good under 2300 RPM but sputters over 2300 RPM. Been told that there is still a timing issue. What else could be the problem?
