2nd Gen Intrepid 1998 through 2004 Intrepids
Overhead Console
Old May 15, 2006 | 12:43 AM
Reswob's Avatar
Reswob
Default Overhead Console
How do you remove the overhead console to replace the bulbs for the map lights?
Old May 17, 2006 | 01:47 AM
SeXyinTrepid's Avatar
SeXyinTrepid
Default RE: Overhead Console
From the service manual -
REMOVAL - OVERHEAD CONSOLE
(1) Disconnect and isolate the remove negative battery cable.
(2) Remove the overhead console retaining screw, located in the front of the console near the windshield.
(3) Using your fingertips, grasp the sides of the overhead console and pull straight down evenly to disengage the two snap clips at the rear of the unit.
(4) Lower the overhead console enough to access the wire harness connectors.
(5) Disconnect the control module, courtesy lamps and if equipped, the power sunroof switch electrical connectors.
(6) Remove the overhead console assembly from the vehicle.
I think the "control module" part only applies if you have an OTIS or an EVIC.
