2nd Gen Intrepid 1998 through 2004 Intrepids
2.7 Ltr blown engine
Old Oct 29, 2005 | 04:41 AM
nickoman01's Avatar
nickoman01
The Only Elite DF Member
Default RE: 2.7 Ltr blown engine
ORIGINAL: 97 3.5 Intrepid
I have also heard that they increased the oil passages, which should help eliminate the problem.
yeah thats what i understood to be the change to help with the problem.
Old Nov 15, 2005 | 11:37 AM
Houstonderk's Avatar
Houstonderk
Those people said they are not working on that case anymore because its to much or something. I have around 80,000 on my 99 and the only thing i've had to do besides maintenance is the evaporator and the valve stem seals are leaking oil alittle. I was planning on finding and converting it to a 3.5 HO engine like in the prowlers and maybe they have superchargers made for factory setup.
Old Nov 16, 2005 | 03:45 AM
nickoman01's Avatar
nickoman01
so your another victim of that POS evaporator?
Old Nov 16, 2005 | 11:33 AM
Houstonderk
Yep. The main reason they go is if its on fresh air all the time since there is no filter on the outside. I always leave it on recurc.
