2nd Gen Intrepid 1998 through 2004 Intrepids
0113 and 0172 computer codes
Old Nov 17, 2006 | 02:39 AM
janika007's Avatar
janika007
Default 0113 and 0172 computer codes
My check engine light is on.Computer codes : 0113 and 0172.
0113 : Intake air (charge) temperature sensor voltage high
0172 : The oxigen sensor is saying that the system air/fuel mix is far too rich
Does anybody know what to do now?What do they mean exactly?
Thanks
Old Nov 17, 2006 | 12:58 PM
kurts2's Avatar
kurts2
Default RE: 0113 and 0172 computer codes
I'm not totaly sure, but it sounds to me like you have a bad air intake sensor, wiring, or computer (I would lean towards the sensor). Assuming the air intake works like the automatic choke system on a carb., that would adjust your air/fuel mixture incorrectly. That in turn is what the O2 sensor is saying. In theroy, fix the one, and the other will be ok. Of course, It may be you also have a bad O2 sensor, but what are the odds??
