2nd Gen Intrepid 1998 through 2004 Intrepids
00’es-exhaust-tire-upgrad
Old Dec 22, 2003 | 11:17 PM
dennis o''s Avatar
dennis o'
Default 00’es-exhaust-tire-upgrad
want to upgrade with aftermarket products-my exhausht-tires-air intake system
Old Dec 23, 2003 | 06:49 AM
71RoadRunner's Avatar
71RoadRunner
Here you go:
www.howellautomotive.com
www.forwardmotioninc.com<edited><editID>71ROADRUNNER</editID><editDate>37978.1617013889</editDate></edited>
Old Dec 24, 2003 | 07:32 PM
dennis o''s Avatar
dennis o'
thanks 71roadrunner for the info., will click the sites-dennis o'
Old Dec 25, 2003 | 06:01 AM
71RoadRunner
Not a problem. There isn't alot out there for them, but there are at least some things for them.
Old Mar 3, 2006 | 04:14 AM
shnormo's Avatar
shnormo
Default RE: 00’es-exhaust-tire-upgrad
K&N is the way to go, if you go with dual, make sure you get a cross over pipe to even out the gas pulses. (It'll help make better hp) There are two ways to do it, cut it at the collector and run two pipes back and two mufflers, or take the old muffler out and get a flowmaster with dual outletts like for a newer Camaro and run two pipes off that. V6 2.7-3.5L use 2.5"-2.75" for best torque and hp.
Old Mar 3, 2006 | 04:59 AM
shnormo's Avatar
shnormo
As far as tires, decent prices, mounted and balanced. http://www.Wheelmax.com
