trans swap
Old Mar 30, 2007 | 02:37 PM
neonracer004's Avatar
neonracer004
Default trans swap
i have a friend with a auto 2001neon se, what would i need to make it a manual.
Old Mar 30, 2007 | 03:59 PM
gabo's Avatar
gabo
Default RE: trans swap
search my lovely friend, search if you might.
Old Mar 31, 2007 | 01:07 AM
03neonRT's Avatar
03neonRT
Direct from "The Official 2nd Gen FAQ and Performance Thread"...
Q: Can I swap in a manual transmission into my automatic Neon?
A: Yes, you can and will need the following: transmission (3.55 or 3.94), modular clutch, passenger side axle, clutch master and slave cylinder, shifter cables and clips, tranny side motor mount from a manual transmission 2nd gen, MTX PCM from your year car, shifter and shifter base, clutch and brake pedal assembly from a 2nd Gen.
However, you have a 2000 so you need to decide if you wnt to stay with the cable clutch or go with the 01+ hydraulic clutch setup. That list I put in the FAQ is for a hydraulic clutch transmission swap...
Old Apr 2, 2007 | 05:41 PM
neonracer004
thank you for the info, that is exactly what i needed to know. i appreciate it
