how hard is it to remove tailights?
Old Apr 1, 2007 | 09:14 PM
Acrfanatic's Avatar
Acrfanatic
Default how hard is it to remove tailights?
How hard is it to remove a set of tail lights? If you can take the time, directions of how to remove them would be nice...thanks a lot guys.
Old Apr 1, 2007 | 09:35 PM
jeremiah2360's Avatar
jeremiah2360
Default RE: how hard is it to remove tailights?
On my 01 it was easy. Three longplastic 13mm bolts and unplug the two bulbs for each taillight. You have to pull the carpet out of the way. On mine I removed the plastic rectangle plate between the the taillights inside the trunk(pops right out and back in)and removed a couple of plastic body panel retainers. I don`t know if an 02 is different but they should be very similiar anyway. They tend to leak so I would get new tailightgaskets while your at it.Good luck.
Old Apr 1, 2007 | 10:09 PM
LowSlowNeon's Avatar
LowSlowNeon
What he said. They'll take you maybe 10 minutes total to take out.
Old Apr 1, 2007 | 10:14 PM
Acrfanatic's Avatar
Acrfanatic
thanks...
